Need Help Fast About Towing!
My ST just died while driving and I need a tow. First guy showed up with a regular tow truck and I refused to let him tow it even though he insisted it would be fine to tow it from the rear. I called AAA and explained so they are sending another company with a flatbed. Can they just put the vehicle in neutral to pull it up on the flatbed or do I have to disconnect the transmission using the switch in the center console?
Use the switch so it can be put into neutral.
That’s what I thought. I just have to find something to flip the switch with. I usually have a small tool box in the back but I took it out the other day and haven’t put it back. Hopefully the driver has something. I’ve read it can be a bitch to flip that switch to! Thanks for the fast reply!
I've seen people use the key from your fob.
I’ll try that. Hopefully it moves easily!
powerboatr
Read the book
Neutral, key one...iirc it's like very low distances
Aaa. And ford roadside..know a flat bed is preferred method
Don't you still have ford roadside assistance
