Oil change
fort lauderdale
2021 ford explorer st
Hello All, does anyone know if I change my own oil that it can void warrenty? I would think as long as I keep receipts of what was bought I'll be fine? Also, for people that don't monitor at home. What oil are you guys using along with filter? Thanks
Canby, OR
No, it doesn't void your warranty. Just keep acurate records of any maintenance you do. I use Mobil1 with a Motorcraft filter.
Unless you mess something up it won’t void warranty. Just make sure you keep everything (receipts, documentation’s, etc.). I’d just use Motorcraft. Mobil1 and Valvoline is good too.
W
fort lauderdale
Thank you!
W
fort lauderdale
Thank you.
As far as keeping track of your at home service goes, the Ford Pass app has worked well for me. It isn't limited to at home service, but you can put all the information you'd like in that with every service.
