I have always done 3-5 gentle heat cycles to seat rings and then its game on. Ill accelerate in a gear, hold the gear, and let the engine brake the car down pretty far then do it again. Trying to get high cylinder pressures and then a bunch of vacuum to really help seal the rings. Had a LONG TIME engine builder tell me about that years ago and its worked well. He does 3 gentle heat cycles and then runs it through 4-5 WOT/engine braking runs and calls it good. Ive done that on cars that "overall" were notorious oil burners and I have never had one burn a drop.
NOW as per the other components(trans and diff gears) that COULD be another story. The trans I dont worry about as much, but the axle gears, they really should get at least 500 miles of easy driving with a few heat cycles. GM in the C7 Corvette recommended nothing crazy until 1500 miles due to the rear end gears. MOST guys(including me) dumped the fluid at that point and almost universally it was NASTY...then it would stay pretty clean for however many more miles, but that first 1500 miles the gear lube was NASTY.
