So your hundred examples are with one tuner? Or does Adams tunes also fall into this category of buy, copy, tweak? Only ask because you directly accused someone of doing that with Adams' tune. I don't really understand how it works but I can't imagine a profitable enterprise if all you had to do was copy someone's work and resell it. Can you elaborate on the 100 times you've seen this happening?
Yes, the files can be locked, and it does make it harder to look at the tables, but not impossible if you know what you are doing. It is not foolproof.
The RTD, while similar to the MPVI2, is lacking in these abilities and is designed for the average consumer.
I hope that clarifies a bit!
- 2
- Show All
