Ordered 22
Buffalo, NY, USA
Did all of you order a sunroof? If you did, that was the reason for the delay. It was on commodity hold (sold out part).... your dealer should start you at PC 10 then it will go up from there. Your progress through the build process is based on MANY factors. One of which is your PC code. Regardless of your PC, it could be moved to PC 2 and you could still be delayed due to a commodity hold. Parts are few and far between right now, its not only chips that Ford is struggling to get it's simple options across the entire Ford lineup.
I ordered mine 11/5, mine is in production. I should have it by mid Feb. I had a build date in Dec for Jan. But I chose to go without the panoramic vista roof. Ford just scheduled a lot of Explorers this past week that were delayed and they ALL had the vista roof.
Lowest priority code for an unscheduled build is 10. Priority for initial orders placed is between 10-19.. with 10 being the "highest priority" but it doesn't really make a difference anymore. Priority only goes below 10 once an order is pulled and has a scheduled build week.
M
Louisville, KY, USA
Thread Starter #22
My car has been built.
ordered 12/11
In production 1/27
Built 2/20
ETA is 2/26-3/4
