P0128 Thermostat Stuck Open
Charles Town, WV, USA
Morning guys, wondering if anyone could give me some advice on this one. Have a code PO128 Thermostat stuck open code. Its not coming up to operating temp so I assume that its either right or the sensors gone bad. Seems to still be blowing heat though so not real sure. I know the best thing to do would be to take it to dealer and let them figure it out but their saying they cant get me in for a week or so... if its simple enough id rather just do it myself. Any insight? Anyone had this issue before?
If it is the thermostat, people have installed 170* thermostats without much fuss. I too would probably DIY rather than wait for the dealer.
S
yeah I can see the housing, doesnt look to bad to get too but my main concern is how much of a pain are these things to burp/get the air out of?
Gsutavo
Nicaragua
I have the same code P0128 a month ago, it is low engine coolant temperature, I changed the thermostat to 170 degrees and the problem continued, they made a diagnosis and it showed problems with the ECT sensor, Ford has a bulletin where it recommends changing the sensor ECT and knock sensor and wiring harness
Gsutavo
Nicaragua
Does anyone know the code or part number for the ECT sensor or coolant temperature sensor? Thank you
S
So oddly enough mine decided to fix itself before I had the chance... ordered a new sensor and thermostat from rock auto... keeping them on standby just incase. Heres the motorcraft part number for the sensor. More Information for MOTORCRAFT DY1446 (rockauto.com)
Gsutavo
Nicaragua
Sorry for the delay, thank you very much for the information, I will ask
Bartlett, IL, USA
Anyone find a solution to this? Having the same issue now where my car won’t get over 150 degrees.
S
Mine started doing again too, its sporadic though. I plan to try to do the thermostat and sensor this weekend, ill report my results.
Gatorst1r
Crestline, ca
I just installed the mishimoto 160° thermostat. About two days after I installed it I am now getting the same code and my car is not running temperature. Could it be that this car just can’t handle that thermostat or is it probably stuck open? I know I could just pop the hood take the box out and check it real quick but I don’t have the time, so just looking for some advice.
They have a specific thermostat for the Explorer ST? I am not seeing it on their site.
Buffalo, NY, USA
I had P0128 show up last week, and in a tizzy I cleared it (in hindsight I should have left it so the dealer could just take care of it). Wondering if/when it will come back on.
My OBDII gauge shows coolant temps around 168-172 during my ~20mi round trips in 70-80 degree ambient air.
Curious what it ideally should be? (closer to 200+ probably?)
The temp gauge on the dash shows slightly below halfway (definitely above the blue cool zone), so without the code or OBDII gauge, I would assume its operating normally... and maybe it is?
Buffalo, NY, USA
Anybody able to comment on what coolant temps I should be seeing?
P0128 has not returned yet; still seeing temps ~170 in relatively short around-town trips.
mgmack
West Palm Beach, FL, USA
I just had the P0128 for the second time. First time was at 1 year, around 12,000 miles, dealer replaced T-stat under warranty. Second time was at just under 3 years, 36,300 miles, covered under the 2 year warranty on the T-stat they installed after the first time I had the issue.
Although I believe T-stat and housing are covered under the 5/60,000 Powertrain Warranty too.
Houghton Lake, Michigan
2015 Explorer Sport
2015 blows cold air at idle, warm/hot aid when cruising... Has anyone heard of this? No codes
