P04DB Code
United States
Explorer ST
I just installed the Fenfab v2 intake and charge pipe with HKS BOV. My car threw a P04DB code on the 3rd drive cycle. I'm sure I installed the intake lines correctly, but what might cause this? 1000004646.jpg
Desert South West
This connector appears to be unseated.
Omaha, NE, USA
Great eye Wafer! Tracked let us know if that fixes it…
T
United States
Explorer ST
I just went out and re-inserted that connector and it appears to only go in that far before clicking on.
Could something with my evap purge valve be wrong with the intake and/or vacuum line install?
Desert South West
Was that sensor originally closer to the 90° fitting as in this picture?
Your code is a Crankcase Ventilation System Disconnected warning, I've read the sensor also has a hall effect pickup that detects when the Vent hose is moved.
T
United States
Explorer ST
Ye
Yeah it was definitely facing in that direction and is no longer. Maybe I need to trim my hose so that it can be repositioned that way as the hose is too long to allow it to go back to that direction?
Desert South West
Ye
Yes try to reposition it to face to same direction and at the approximate distance from the fitting, hopefully it will clear the trouble code.
