Radio Presets in 2025 ST
The owners manual doesn't seem to answer this question. Does anyone elses 2025 radio presets display both FM and AM presets no matter which FM or AM band you are on? When I'm listening to FM radio, the single AM radio preset I have (to listen to certain college football games) shows up.
Not sure why this is or why Ford would do this. If I'm on FM radio, I only want my FM presets showing, not both FM and AM.. . Also, does anyone know how to delete a preset station?
I Bleed Ford Blue
23 Rapid Red Explorer ST
I don't think you can delete a preset, you can change to any station you want, but you can't delete it. Typically to change a preset you just manually tune to the station you want then press and hold the preset you want to use until the new station becomes locked in.
C
I found how you delete presets. You push and hold on the preset station and then you drag it off to the left, and it deletes it.
