Triangle piece is the overlapping heat shield that contacts the body if vibrating at high speeds.I am pointing to the clip that was basically off and the bolt near the rear wheel threaded on by two turns. I am also pointing to a location behind mid pipe where bolts were also could be tightened, the pictures are not all inclusive. I suggest you hunt around with a wrench and start tightening everything.
I also examined control arm, sway links, on front right side, nothing appears to be obviously wrong to create a low speed clunk in the passenger front. Even poked around the battery bay, nothing obviously lose.
I have an appointment Thursday at the dealership to deal with the clunking sound from the front end at low speeds.
