Rear end damage
ghostfranklin
Miami, FL, USA
@st8 I think either would work, I would tweet them first because that puts them on blast in a way. I'm no social media influencer (I barely have any followers nor intend to gain more) or anything but you don't want customers complaining on your main page about one of your "flagship" vehicles. I think they want to keep their main page clean so they'll reach out quickly to take the conversation to the DM.
st8
Bel Air, MD, USA
That makes a ton of sense. Will do! Thanks.
ghostfranklin
Miami, FL, USA
Just finished Ford reiterated what other folks have said in this thread. No issues, no recalls, no TSB, nothing from NHTSA or some over gov agency. Verdict is be careful and break these subframes to get what should have been put on the car originally.
What a shame for 50-60k there's other options I noticed someone mentioned BMW prior and Americans wonder why they say "they dont build em like they used to". What a waste of time. With my luck it will break on the hwy on the way to a vacation with the family after hours. Oh well. Good luck, be safe.
st8
Bel Air, MD, USA
I mean ultimately they had to of done testing to come to these conclusions right? I mean one year you do 4 bolts. Then decide 3 is appropriate. How do you come to that conclusion? I know it’s about saving money but they also can’t possibly risk such a delegate part of the drivetrain.
FORZDA3
Gloucester, VA, USA
Based on previous Ford Performance history and what ghost said, at this time Ford doesn’t have any incentive to offer up the fix to all cars affected. Some cars with the 3-bolts will have no problems at all, so Ford would “waste” money by changing them out. So, if you have a failure Ford will repair it and install the correct part. It’s all about Ford not seeing any liability problems, only a few cars that joyriders break. Even then, Ford will attempt to deny any warranty if they can.
All this is why I just bought the correct part MB5Z-5035-E for mine and will replace it myself, so I can run the E50 tune!
ghostfranklin
Miami, FL, USA
@FORZDA3 how hard would it be to break this and have them do it? Brake boost and launch hard a couple times? I think my best bet would be if it breaks stock bc I can already hear the warranty claim being denied with the mods I'm doing. I think OP got extremely lucky. I agree with you on not letting some ford tech who doesn't give a damn touch the car but if I remember correctly the part alone is $1,700 not including labor (I don't have the means or technical ability to do this on my own anyway).
st8
Bel Air, MD, USA
All this is why I just bought the correct part for mine and will replace it myself, so I can run the E50 tune!
Yeah I see. Isn’t there a rubber bearing around the bolt? Isn’t it reasonable to just monitor that rubber piece? And if it starts to break/push in, bring it into ford and say this bolt will be breaking soon.
st8
Bel Air, MD, USA
I’m guessing it takes a significant amount of abuse to actually break this. Exception being the rare incident where it breaks easily for whatever reason. Just like anything can break in a car but 99% of people won’t have an issue. I could be wrong. But I’m guessing that’s why ford is okay with it.
the thing I can’t get behind is the aviators are getting the 4 bolt treatment still.
RobHalo
NJ
I wonder if there was any incentive for an engineer to find a way to save a few bucks a car by subtracting parts? What really "bothers" me about this change is how minor the cost savings must be. They must have been very confident in the math that showed few failures will result. It doesn't mean they're right, but they must have been confident.
I Bleed Ford Blue
23 Rapid Red Explorer ST
It's basically because of the bean counters. They calculate how many 3.0L explorers will actually break because of the missing bolt and how many will know that it happened because of fords penny pinching and then how many will sue ford to repair their car vs how many will pay for it themselves. In the end they determined that the wrong subframe and 1 less bolt will save them more than what they will pay out in lawsuits and repairs. Happens all the time with ford.
Its called "value engineering" in todays world....... Everyone does it some hide it better than others......
I Bleed Ford Blue
Your probably right, but I haven't owned anything other than ford in 20 years so I can't speak on other brands.
FORZDA3
Gloucester, VA, USA
I’m not so sure it was a long-term change by Ford. It’s really odd that all the newer STs don’t have the 3-bolt setup. It looks to me like a temp solution to supply chain problems so Ford production line could get new cars out to dealers. I think it was a “local” decision made by a Field engineer, not a Design engineer. This is why the Ford Parts system shows 4-bolt setup MB5Z-5035-E for the STs, even those with 3-bolts.
I plan to cruise all the Ford/Lincoln dealers showing ST/Aviators in stock (within reasonable distance in my area) with a flashlight and knee pad to check them out for my theory.
FORZDA3
Gloucester, VA, USA
@FORZDA3 how hard would it be to break this and have them do it? Brake boost and launch hard a couple times?…
Yeah, I don’t think there’s any way to break it at will, on purpose. It would take some experimenting and broken parts to figure that out. If you can’t do the job yourself and decide it costs too much, the best bet it to forget about it and just drive the car. You may never have a problem, especially if stock or running a non-E based tune.
I’m not so sure it was a long-term change by Ford. It’s really odd that all the newer STs don’t have the 3-bolt setup. It looks to me like a temp solution to supply chain problems so Ford production line could get new cars out to dealers. I think it was a “local” decision made by a Field engineer, not a Design engineer. This is why the Ford Parts system shows 4-bolt setup for the STs, even those with 3-bolts.
I doubt this was a transient supply side issue. If that were the case, wouldn't there be reports of 4 bolt STs from 12/20 up until now? That's over a year to have supply chain issues. Meanwhile, Aviator owners that have chimed in report 4 bolts in that same time frame. Granted, forum members are a small sampling but no member of this forum with ST's built after 12/20 have 4 bolts??!? What would be the odds of that!?
To me, it's pure cost cutting and betting the failures are few or occur after warranty expires. For all we know, this could be just one of many cost-cutting measures. What if they put in the smaller rear sway bar? The non-ST shocks/struts? Most would be none the wiser...
ghostfranklin
Miami, FL, USA
@FORZDA3 I'm going E85 with full exhaust, whipple FMIC, aFe intake, HPFP w/injectors. Adam from ZFG estimates I'll have ~550 awhp, I have the diffy stiffy as well I picked it up without even realizing the subframe issue just to add support for pushing close to double the crank power. No I don't race on weekends or go to the drag strip frequently I would just hate to get on the road and break down on the way to pick up the wife and kids, or something extremely inconvenient Would you replace the subframe or you think the diffy stiffy will save me the hassle?
st8
Bel Air, MD, USA
All the 2022 STs have the 3 bolt design. From what I have seen.
See my posts here:
https://www.explorerst.org/threads/...oom-from-emergency-auto-brake.2148/post-36529
