Rear end damage
Miami, FL, USA
2022 Explorer st
Based on the document above, what type rear axle bolt configuration will the ST's have when built AFTER April 11,2022? Is Ford adding back the additional axle bolt?
mine was built 5/12/2022 and it has 1 bolt
st8
Bel Air, MD, USA
I had someone on Facebook tell me the 3 bolt design is now correct but there was a batch of bad 3rd bolts that were breaking.
CareerFiremanGuy
Actually, that makes more sense than anything I've heard thus far.
If that is the case, then FORD should simply replace the bolts.
st8
Bel Air, MD, USA
Yeah who knows the actual truth. Wish we had someone on the inside. I wonder if ford will ever consider a diffy stiffy or whatever it’s called.
CareerFiremanGuy
Whoever knows isn't talking. Lol
Not sure they would go with the expense of a diff brace if it only needs some updated bolts.
GTB1
Detroit, MI, USA
Is this the same rear axle bolt recall where they fix it with only a software flash that keeps your electronic parking break on when you are in park or start up which you then have to disengage or hit the gas pedal to automatically disengage which makes the car lung forward or backward? That's what my dealer did after misleading me into thinking they were fixing something mechanically. I asked them if it coudl be reversed and they said no.
CareerFiremanGuy
Well, your dealer didn't really "lie" in that this is FORD's response to the vehicle not rolling away in the extremely rare event there's a bolt shear.
As such, it addresses a safety issue and under no circumstance would it ever be reversed.
I have used my ebrake since day one of ownership almost 3 years ago and it NEVER lunges or has problems engaging or disengaging the e-brake when parked. People really need to calm down about this e-brake thing. I wish mine automatically disengaged so I wouldn't have to remember to do it every time I park! LOL My driveway has an incline so I never park without the brake on.
Ontario, Canada
I also use my parking brake everytime (okay, almost), but I just hate being told I have to use it.
CareerFiremanGuy
... People really need to calm down about this e-brake thing ...
100%
... I just hate being told I have to use it.
We get that, but overall a non issue when compared to seriously meaningful things.
Airizona
Your vehicle doesn't do this? I have the habit of setting the brake too, but just tapping the gas in drive or reverse releases the brake without me doing it if I forget.
Sorry I meant I wish it automatically ENGAGED. Mine does auto disengage.
Airizona
ah ok, I thought they all worked the same for that haha. I had the recall done and it did auto set, but then I flashed my tune again and it wiped it out hahahaha. Oops.
I Bleed Ford Blue
23 Rapid Red Explorer ST
Same thing happened to me after I had the recall done.
69BOSS302
Edmonton
Just spoke to my dealer about my 2022 ST and they said they are out of parts, but once in I will get a letter explaining how to get my one bolt replaced. Waiting to hear if it’s a new subframe. Standby…
Philip
CareerFiremanGuy
I don't see FORD offering anything but an e-brake re-flash. New subframes on all of the 252,936 cars involved would cost them 758 million dollars. Not happening ...
69BOSS302
Edmonton
That sounds reasonable they won’t be replacing the subframe however I’ve already had the park brake enabling upgrade done. Thats why I’m waiting to see what my dealer tells me.
3rd Rail
New Milford
Explorer ST ‘22
758 million is not much in the bigger picture.
That's a huge amount in Ford's eyes until someone dies. Ford lost 1.3 Billion in 2020. Put that into perspective.
CareerFiremanGuy
No company is going to spend 3/4 billion dollars on something that's only effected .09% of their product unless it involves a life threatening issue.
Exploding gas tanks, yes. Engines self igniting, yes. A bolt shearing, nope.
