Roof rack delete
Surrey, BC, Canada
Hello
Does anyone have any detailed description or picture information on how to remove the roof rack from the ST?
Any help would be appreciated!
Tucson, AZ
Probably similar to this
S
Surrey, BC, Canada
Thank you very much for your reply..
The roof rack on the ST is quite different than the '18 Explorer, don't want to damage anything
The Woodlands, TX, USA
I haven't seen any instructions yet, someone is bound to remove theirs and post a video on youtube.
S
Surrey, BC, Canada
So I found out if you want to remove the roof rack you have to drop the inside headliner to get to the six nuts that hold it attached to the roof. Unbelievable
S
Surrey, BC, Canada
Was it a pain in the ass?
Not too bad, About two hours... Very carefully dropped each side of the inside headliner to get to the nuts that secure the rack to the roof. Patience is a must not to damage the liner... Make sure you have the right tools...
Fort Benning, GA, USA
What did you do to stop the holes from leaking? :unsure:
Skunk Hollow
Factory Insert Part #'s:
Part Number Part Name Price
LB5Z-7850462-AARoof Molding
LB5Z-7850463-AARoof Molding
$207.21 ea
Source: Levittown Ford Commercial Parts Sales ............ Benny is the contact. IMG_20200517_184450.jpg IMG_20200517_184407.jpg
Grand kids play room ............. Can you tell ? :rolleyes: These will be installed tomorrow at the N TX LEA skunk works.
Skunk Hollow
Front of the trim inserts ............
Skunk Hollow
And when you have a water leak and the mothership rejects the claim ?
S
Surrey, BC, Canada
Thread Starter #18
Understandable and valid concern!
With do diligence, clean workmanship and 40 years in the construction industry, I am VERY confident that no leakage will ever occur
Skunk Hollow
We have a miscommunication. Ford does not, will not give a rats a** how good a job you did. Their point will be that you did not install the correct replacement parts. IE: The inserts used on the PIU or, the XLT with the roof rail delete box checked off. If you never have an issue, you're gold. If it fails, you are up the creek. This is a darn near $60k vehicle. Why jury rig it ?
S
Surrey, BC, Canada
Thread Starter #20
You
You are absolutely correct sir...
We do have a miscommunication...
As I have stated previously, I am 100% confident in my "jury rigging" non OEM Ford parts to achieve the same result you will have. Having confidence in my workmanship greatly out ways any worries about not being "covered" by Ford. Don't see any reason to line Ford's pockets any more than I have to, to achieve a simple non-mechanical mod..
That's just my take on it of course....
