S&B or K&N CAI
Ephrata Pa 17522
2024 Ford Explorer ST
Anyone go down that road?
If so, what tuning did you do afterwards?
K&N looks like crap IMO. Neither will gain any power, honestly if you’re wanting an intake, I’d push you towards the Fenfab least you can get some awesome turbo sounds.
Iowa
2022 Ford Explorer
K&N, S&B, and AFE all connect to the same fresh air duct in the grille. Which is about half the size of your drop in filter. Fen Fab is the only intake that doesn't have that as a restriction. However longer inlet pipes also make the turbos less efficient.
All the tuners say you don't need a retune for an intake. Mainly because the EFI is speed density. The factory computers can tune for +/- 10,000 of air density which is nearly 5 PSI of ambient air pressure.
