Seeking some advice on a BOV
LocoEngineer
*Shopping
S
Chicago, IL
2025 Ford Esplorer ST
Thread Starter #22
Update on the BOV for my 2025 just want to throw it out there in case anyone doesn't know, for the 2025 model i am finding out that you cannot do a cold side charge pipe with the stock Intercooler if you want to do either hot or cold you need to upgrade the IC as well
There are adapters to accommodate the change in the connections, if that’s what you are referring to. I believe you need them even with an aftermarket IC.
S
STBan
Chicago, IL
Thread Starter #24
See i tried to look for some but i could not and i asked around but everyone kept saying you need to change out the intercooler because the cold side charge pipe will not fit the stock one which i was trying to avoid for now cause i wanted to focus on other things
