Smoke from exhaust on startup
Cali
22 Explorer ST
Hello all, we recently purchased a 2022 Explorer ST late December of 2024, and recently noticed on startup the exhaust blows a blueish colored smoke for about a couple seconds then goes away. On this website I have noticed that there were some out there that had the same issues, and most were replacing the turbo chargers to fix the issue. We currently still have warranty on the ST. Now my question is if it is the turbo chargers, would they leak again in the future? Also not sure if its the reason but we park in the driveway at an incline and reason why I say that is because some brought that up too. Any information regarding would be great. Thank you
Dallas, TX
If the turbos started to leak, they'll continue to leak. Other causes could be bad valve seals or bad compression causing oil blowby. Of those two, since you only see the smoke on startup, it'd likely be the valve seals. Constant smoke while driving, or puffs of smoke when taking off from a stop light is usually bad rings.
I'd guess it's the turbos though.
A
Cali
22 Explorer ST
Right on thanks for the information. We have an appointment tomorrow at the Ford dealership and will follow up on it to see what they find out. Im glad I have warranty on it lol.
It’s not the turbos that are bad it’s the turbo seals most likely. Being on an incline shouldn’t change that, just coincidence most likely. If they replace the turbo seals, they most likely won’t leak again.
A
Cali
22 Explorer ST
Thats what I kinds figured being parked at an incline shouldn't have any effects. As soon as I get the ST in I will update it here.
Welcome to the forum.
A
Cali
22 Explorer ST
Thank you! I really appreciate it
A
Cali
22 Explorer ST
Update: So I finally got my ST back after over two weeks at the Ford service station. Turns out it was a bad driver side turbocharger. What is weird is that the only way to get the smoke from the exhaust from the station was to simulate parking at an incline like my driveway for the smoke to appear. But alas, finally got it back covered by warranty and ready to go.
