Thank you all for your reply. It has taken me awhile to get some info as I’ve been trying to work with Ford and my dealer. This only occurs on cold start-up, and when the SUV is parked on an incline (engine facing uphill). When I park it backwards (engine facing downhill), the smoking issue has yet to occur. For clarity, anytime the vehicle does smoke on startup, it smells burnt/like oil.
Here is where we are with the issue:
I enlisted the help of Ford, and they worked with my local Ford dealer to address by having the dealer communicate and troubleshoot with a Ford engineer. After two weeks of troubleshooting, they came back and said they have found no issues with any potential part failures, and are tentatively ruling it like this: that this is a normal situation that when the SUV is parked on an incline, it will smoke under those conditions and will not cause harm.
The only other thing they are having me do is drive my car for 3k miles, and then I have to take it back for them to see if there has been any oil burn off. If so, they will continue to investigate. If not, that is where Ford is leaving it. Doesn’t really make sense to me and I hope to get something figured out.
