ST - Storm Trooper Build
Nbk4t5e
Nbk4t5e
San Antonio, TX, USA
Thread Starter #341
Let the games begin. I’ve decide to cut into the vent a little to make sure the gauge is completely seated behind the frame showing no edges and will be a snug fit. Happy with the results! Very tedious project!
Put a strip of matte black vinyl to accent with the vents and not show any flaws on the cuts from the dremel.
Wiring for ethanol will start tomorrow.
Plano, TX, USA
That looks amazing, nice work, it looks like it came from the factory that way. If I recall, this is the wifey's car, doesn't she get impatient with you hot rodding her ride all the time, lol. Are you really building it for her or you?
Nbk4t5e
Nbk4t5e
Thread Starter #343
Lol… sometimes impatient but she loves it and she supports my need for speed. I have my company F150 so I don’t have anything else to work on at the moment! The build is definitely for the both of us.
Stinger
Active Duty U.S. Navy
Madison, WI, USA
Damn
That’s some nice work.
Nbk4t5e
Nbk4t5e
Thread Starter #345
Damn
Thanks a lot. Finishing the wiring right now.
Nbk4t5e
Nbk4t5e
Thread Starter #347
Hard wired into the OBD wires so I still have access to the port if needed. Soldered most of the wires but these little T connectors are badass on Amazon. Worked like a charm with the 22 AWG wires. I’ll get to the fuel lines one day.
Nbk4t5e
Nbk4t5e
Thread Starter #350
I forgot to ask, how difficult was the steering wheel install?
It’s not hard at all. You’ll notice 2 small holes on the side of the steering wheel. Use something to get in there and press somewhat hard to release the spring to the airbag. (One on each side) disconnect it and use a T50 torx bit in the center that hold the steering and that’s it. I can do it in under one minute now.
New Orleans
Not bad at all! I think I’m going to order the wheel!
Nbk4t5e
Nbk4t5e
Thread Starter #353
Nbk4t5e
Nbk4t5e
Thread Starter #354
1st wide body and front splitter coming soon.
Nbk4t5e
Nbk4t5e
Thread Starter #355
Courtesy of @F=MA …. Nostrum HPFP and injectors …
Hopefully will install in a couple weeks with a full E85 tune
For now :)
Nbk4t5e
Nbk4t5e
Thread Starter #356
Finally going custom on the exhaust
Nbk4t5e
Nbk4t5e
Thread Starter #357
Getting close
Dang.... that setup is gonna be LOUD. [rockon]
Nbk4t5e
Nbk4t5e
Thread Starter #359
Oh yes.!! We cold started it earlier, it’s pretty loud but may add a set of 12” resonators in the rear also if there is any rasp.
Nbk4t5e
Nbk4t5e
Thread Starter #360
Tips are set …. Actually digging the chrome. These were a set of black AWE tips from a BMW M5 aftermarket exhaust. Once complete and no rasp we will coat the rear section satin black.
