Steeda or aFe Sway-Bar?
blackdog
MA
JR,
Thank you for posting useful information pertaining to the subject at hand. Understanding the results of a suspension change is far more than an article from car and driver review of the truck. That's a great site you have, and thanks.
The midwest
My pleasure. After 20 or so years with IRS vehicles, I’ve been fortunate to pick up a trick or two. The ST isn’t as fun as my Cobra, but it can be improved nicely though!
blackdog
MA
Many, many years ago I owned and drove a dirt track car and Bobby Allison put some time and money into it. He did that because a close friend was a member of the team and his brother was a NACAR driver. He taught us about suspension to a small degree and all I can remember from that is "roll out" as it applies to tire diameter. Not applicable if you're turning left AND right.
So, when stiffening only the rear wont that result in a bit of front end push or a bit of dive?
Thanks again.
Thanks again.
All of the information posted answers that question. No, it will not.
blackdog
MA
correct, but that figure relates to the trucks weight and COG. And that changed with the RWD chassis setup.
Yes…closer to 50/50 but that doesn’t change how these bars interact with the chassis. It’s still an IRS car.
Sacramento, CA, USA
You're stating above that the Steeda "gives it a good balance" so I'll assume you're talking about the ST and roll balance between front and rear. I'll also assume that if you make that statement you've tested them. You are correct with your statement concerning the need for front and rear sway bars to reap the full benefits of either as it only possible to adjust and balance the roll rate if you have both the front and rear installed (AFE only.).
Yes, I drove the stock ST on the Park City auto cross track in the rain, and it was obvious the amount of 'push' in the stock set up. The Steeda Sway Bar is stiffer than stock and gives the ST a more balanced handling characteristic, although I have not driven my own vehicle to the same extremes in the rain, I can tell the difference. And another user posted that he had tested with the Steeda bar on all three settings, he said there was not much difference but very little push. So that tells me if a larger front sway bar is installed then a much larger rear sway bar is also needed. The AFE specs state their rear sway bar is stiffer than the Steeda so my guess is that it matches better with their larger front bar. They should be matched to create a more balanced handling experience. But for my grocery getting ST I thnk the Steeda rear is more than adequte. Just my opinion.
Oregon
#29
So……installing just the rear AFE bar is a good thing? This thread is all over the place.
The midwest
#30
Read Post #20.
Chuck Henson
Middle Tennessee
2023 explorer st
#31
I've searched high and low for an honest review or video of the AFE rear swaybar to no avail,so I'm going to take one for the team and install just the rear swaybar alone.
I will be starting off with it in the middle position.
I will do this before adding any of my other suspension bits just to get a final answer to this all to evasive question of is it good or not.
Wish me luck as apparently I'll be the only one in the world to actually do it.
I've searched you tube,google,these forums etc and all I can find are reviews of the ole blue and rusty steeda swaybars,so no sense in discussing as we all already familiar with those.
I do not want a blue bar that's only going to end up looking worse and I like to be able to grease mine without taking it apart.
Dunno where you get that from but plenty have installed the afe rear bar only and even more have played with the settings if you take both bars into account. Save yourself some time and just set it on the firmest setting to start…that’s where you’ll wind up anyway. The afe bar is just as good as the Steeda bar. I have a first run Steeda bar with zero rust…not all of them have an issue.
San Francisco
2022 ST
#33
I'll be following right behind you Chuck. I grabbed the aFe bar during their 15% sale. (As good a reason as any to buy it)
Chuck Henson
Middle Tennessee
2023 explorer st
#34
That's just it,there are no reviews to be found.
That's why I came here and then it got way off track and the question never got answered.
I'm sure someone else has to have one,yet they're absolutely no reviews on the afe bar at all,anywhere.
Lots of folks having pr
Plenty of reviews and first hand experience on some of the FB groups.
Chuck Henson
Middle Tennessee
2023 explorer st
#36
I'm sure someone else has to have one,yet there are absolutely no reviews on the afe bar at all,anywhere.
Lots of folks having problems with rust on the steeda bars and they're blue which clashes hard and they have no grease fittings and on some reviews folks claim they squeak even after being lubed with the supplied lube,so I would have to potentially take it apart to regressed every time that happens.
I really like steeda alot and have several items from them,but definitely not using their swaybars and as far as I can see afe is the only other choice next to an inferior pui factory bar.
I may as well start on the firmest setting as you suggest and go from there as I do expect the possibility of tweaking in that area regardless of brand.
Hopefully soon I'll give a review on it good,bad or ugly,I will give an honest review.
I actually hope it's good or I'll have to buy the steeda bar and sand blast it and have it powdercoated.
