Steeda rear sway/HR springs fitment
Iowa
Steeda got back to me. Looks like everything is ok to proceed. Which is good:
"The rings are tack welded, we have designed this bar to eliminate having to weld them completely. The notches on the inside of them are to hang them from the powder coating rack. The bar is complete and safe to use."
FORZDA3
Gloucester, VA, USA
what happens if you switch to the firmest setting hole? seems like that's where most of us are seeing the fitment issues...at least that's where i am..
The firmest setting is the first hole farthest from the spring. The closet hole to the spring is the softest setting for the bar. It's simple physics.
