One of the great things about my new wheels is seeing the brakes; the downside, they’re puny. The upside, I get (need) bigger brakes!
Through Lethal Performance, I ordered the Superforged BBK. The brakes arrived yesterday, and they are MASSIVE: 405mm (16”) front, 385mm (15”) rear. They’re slotted, two-piece design; aluminum hats with iron rotors.
When people upgrade to bigger brakes, you always hear them tell you how much their braking improved; that it stops shorter and has less fade. Thing is, nearly no one provides any quantitive data. They assume because they have bigger brakes, they automatically stop better. Sometimes, that’s not the case. Larger rotors dissipate heat better and don’t overheat as easily. The two-piece design is lighter, and prevents heat dissipation to the wheels.
The biggest thing to improve braking is your brake pads. You can upgrade to bigger brakes, but if the new pads are not as aggressive as the old pads, your braking can actually get worse. So before I installed the BBK, I decided to test the car in its current form.
I used a Draggy to measure distance and time to stop from 60mph. Draggy doesn’t offer a different speed to test from, but Motortrend test cars from 60mph, vs 70mph like Car and Driver. This meant I can compare braking performance to various cars
My biggest mod to improve braking over stock is my upgrade to wider, stickier tires. I currently run 315/40/22 Michelin Pilot PS4 SUV ZP on 22x10.5 Vossen HF5. They’re 40mm wider than stock. Besides being wider, they’re also considerable softer, 300tw vs 500tw. I also have lowering springs. They provide little improvement to braking performance.
Stock the ST needs 114ft to stop from 60mph.
I did 13 runs. I didn’t do anymore as the pedal travel started getting a bit long. My current setup has me stopping from 60mph in an average of 2.48sec, covering 107ft. A significant improvement. For comparison sake, below are stopping distances compared to a variety of cars:
2020 GT500 w/o trackpack: 100ft
GT350: 100-102ft
2016 Mustang GT: 109ft
Honda Accord: 114ft
Corolla GR: 110ft
Focus RS: 104ft
Civic Type-R: 104ft
Hellcat Challenger: 109ft
It’s now better than some decent performance cars.
I’m writing this from my computer, so I can’t post the Draggy results. You’ll just have to take my word. If I have time, I’ll post some screenshots tomorrow.
In the meantime, enjoy pics of the new brakes before install.
GT350: 100-102ft
Honda Accord: 114ft
Corolla GR: 110ft
Focus RS: 104ft
Civic Type-R: 104ft
- Show All
