Sync 10" to 8" Screen (Downgrade) Upgrade
Chamorro85
Round Lake, IL USA
'21 Explorer ST
Great write up, always wondered when someone would actually do this.
Chattanooga, TN
2022 ST
I
i8iridium
Maryland
Thread Starter #23
Were there aspect ratio or portrait to landscape issues you had to overcome?
No, changing the below underlined value in Forscan tells the APIM to use the 8" screen.
7D0-03-01 xxxx 00xx xx--
Virginia
Does switching to the 8" screen still retain the massage function options?
I just completed the downgrade to the 8” screen. The only value I changed in FORScan was the APIM ASBUILT 7D0-03-01 “0802” to “0502”.
My driver massage settings are now limited to Rolling Up Back and Rolling Down Back and my passenger massage settings don’t work at all.
Has anyone else encountered this?
I
i8iridium
Maryland
Thread Starter #25
What does this mean? You should only be changing to the value in bold... 7D0-03-01 xxxx 00xx xx--
dynamix
Weatherford, Tx
Dumb question and forgive my ignorance on this, but would it be possible to mount the 10.1 display in landscape? Is there a way with forscan or something to tell it to rotate the view?
Ryan1024
Mount Pleasant, PA
For the backup camera, can it be displayed full screen without the 360 screen?
On the 10” you can hide the 360 and make backup camera full width
Ryan1024
Mount Pleasant, PA
Why yes, Ryan, it can! Just press the 3 lines in the top left corner
Las Vegas, NV
The swap looks great, and still something I'm seriously considering. My question is how do you switch from Carplay back to the main vehicle screen, like to get to the audio or factory navigation links? Thanks!
Jacksonville, FL, USA
#31
But you can’t make that change permanent, can you?
mdl3v8
Kansas City, MO, USA
Explorer ST
#32
The 10" horizontal screen from the Aviator kinda sorta fits with a little ingenuity.
RVAWalt
VA
Can we get some more information about this swap? Just sourcing the parts and what changes were made in Forscan for this to work?
Taken from Facebook
Part #s are kinda wonky, seems Lincoln has changed the screen part # at least once since 2020 and Ford has updated some of the parts as well. You should be able to find all of them on ebay if you look regularly. Keep in mind there are two versions of the 8" vents one has the chrome trim the other doesn't.
I did the swap last weekend pretty easy, once some of the 3d printed mounts come out the finished product will look better.
Air Vent Panel from Explorer with 8-inch screen.
2020 - 2023 FORD EXPLORER CENTER AIR VENT TRIM PANEL LB5B-19F648-BC
2020 Lincoln 10-inch screen
2020 LINCOLN AVIATOR DASHBOARD INFO DISPLAY SCREEN RECEIVER LC5T18B955UH OEM
Tray under screen from 8-inch explorer ST
Stowage Box
Part #:LB5Z7813546AC
I already had Forscan and a usb to obd cable to perform the needed changes.
Forscan APIM change Brand to Lincoln and Visual Design Variant to Lincoln My20 10in
On android auto you press the button in the lower left corner and select the Ford icon or the Lincoln icon if you did the switch to that screen. I am sure its some what similiar on carplay.
#37
Toronto, Ontario, Canada
#38
Taken from Facebook
Stowage Box
What was the total cost of this swap off the top if your head. You got me thinking now
#39
Also I wonder if the 2024 escape screen would fit. I believe it's like 14 inch screen landscape.
Fitting and getting the APIM to report the correct resolution are two different things, the reason the Lincoln screen works is due Aviator and Explorer using the same hardware behind the scenes and being able to select the Aviator profile in Forscan.
