Sync 10" to 8" Screen (Downgrade) Upgrade
Toronto, Ontario, Canada
#41
Fitting and getting the APIM to report the correct resolution are two different things, the reason the Lincoln screen works is due Aviator and Explorer using the same hardware behind the scenes and being able to select the Aviator profile in Forscan.
Ah OK that makes sense. Thank you.
Suprawill1
Maryland
Couldn't see where it might be posted in this thread but ...
Everyone seems to be gearing up on the Aviator screen. Wouldn't the 8" landscape screen work? I've seen it in the '23 Explorer. It was the ST Line though, not the ST. I would think the transition would be pretty easy given the availability of the physical parts already being used. The electronics may be a different story at getting it to communicate with the smaller screen in the different orientation but the '23 ST Line is doing it.
Thoughts?
That was the original swap, both work the same however the 8" screen is 100% OEM because well it is. There are cosmetic issues with the Lincoln swap that some people do not want to deal with.
Suprawill1
Maryland
Oh, ok. Is there a thread on the original swap?
TRF, MN
I believe this is the thread on the 10" to 8" swap.
Suprawill1
Maryland
Ahh! I came in on the wrong page. Thanks! :)
San Francisco
2022 ST
#48
I have great appreciation for this thread, as the engineers/product designers who did this to us should be dragged out into the street and shot.
That said, Ford corrected their monumental f***up for the 2025.
My only question is will we be able to upgrade to the new horizontal layout from the 2025 in our older models?
Don't think so. If I understand it, the system software will be Google-powered instead of SYNC 3 or 4. Perhaps better said, that it won't be a simple hardware change. I'd have to think it's a hardware-software combination package. Now will someone be able to make things work? Never count out the human nature to make things the way we want them. The mother of all inventions.
Wisconsin
2024 Explorer ST
#50
New 2024 ST. Don't like the 10 inch screen but can the 2024 ST with out the 401 upgrand give you the 8 inch screen work? "The standard models boast an 8-inch touchscreen display, Bluetooth® technology and smartphone integration through Apple CarPlay® and Android™ Auto".
I really want to swap out that dumb tall 10 inch screen.
rcflyer
Rochester
2021 Ford Explorer ST
#51
Decided that I was annoyed with the format of the 10" screen and how small the cameras and carplay was compared to the 8" screen. There's not a lot of instructions in this thread. I'll link a video to the disassembly from 4Dtech showing how to "upgrade". That makes it pretty clear on how to take everything apart and where the parts go.
List of Parts
  • 8" Sync Screen - I searched eBay for 2020-23 explorer screens until i found one that was an appropriate price and in good shape - https://www.ebay.com/itm/144466632995
  • Sync3 LVDS Video Harness - This is the cable connecting the APIM to the screen. The 10" screen cable won't work because of the orientation of the connector. You can shave out the spot in the 8" screen back, but I didn't want to do that. Ford part was on national back order, so I turned to amazon. https://www.amazon.com/dp/B089R57XHQ
  • LB5Z-78042A82-AB Trim Bezel Insert $9.69
  • LB5Z-7813546-AC Utility Box $31.45
  • LB5Z-99018B40-CA Trim Bezel $91.20
  • LB5Z-78046B46-AAUtility Box Mat $51.40 (I have no idea why this stupid mat cost 51 bucks, but I was all in. lol)
  • A good attitude.
I followed the video for disassembly/reassembly and swapping out the vents. I also left the original cable in place because I didn't feel like fishing it out. Also, the new cable was a little bit long, so I had to coil it up behind the dash. Make sure you wrap it and tie it good so nothing rattles. That's pretty much it. Pictures follow. Also added some "features" with forscan to add full climate controls to the screen along with the heated seats and wheel.
The must do change in Forscan to get the screen size right: (Don't change x or --) 7D0-03-01 xxxx 00xx xx--
And before anyone asks-I am not selling my original parts.
View attachment 17648 View attachment 17649
This may be completely unrelated to the screen swap. I want to know how you got the climate and CarPlay to show up on the bottom as a menu item? I am running the latest Sync 3.4 23188 version and that may be why the difference. I have a 2021 ST and cannot figure this out. Also my seat and steering wheel icons don't show like yours.
djsparxlv
I couldn't measure it with a tape. So just used the air volume knobs on both sides as a rough reference to see the difference.
The red squares are roughly the 10 inch camera window sizes. So it has indeed grown a good bit.
Same with the car play.
With that added cubby below the screen, I would say a worthy up(down)grade. I would definitely try this, provided I can get those parts from a salvage yard.
I found everything on eBay and for a little less money than the original poster spent.
djsparxlv
List of Parts
  • A good attitude.
When I changed the code from 7D0-03-01 xxxx 0802 xx-- to 7D0-03-01 xxxx 0002 xx--, it had no effect on the screen going to horizontal mode. But when I changed it to 7D0-03-01 xxxx 0000 xx--, it changed the format to horizontal. I like it SO much better! UPDATE: I went back and changed the 7D0-03-01 xxxx 0000 xx-- to 7D0-03-01 xxxx 0002 xx-- because I noticed that the "02" code was the designation for AWD so I didn't want to change that! It works fine with the original poster's code of 7D0-03-01 xxxx 0002 xx--
djsparxlv
Look at my ForScan code note above
Jessup, MD, USA
#55
Can you use the 8" screen in a 10.1" car without doing all the trim pieces? Or will it look very odd?
djsparxlv
not sure about that. might look a little odd
Hull, GA, USA
#57
List of Parts
  • A good attitude.
Does Waze open in the full screen now?
I have the 10 in my car and the 8 in a rental I have right now. After seeing it in person there’s no way that’s a valid swap. That thing is tiny.
