So my order finally was delivered and install was no issue until mounting the 13.2” but the air vents coming from the 10” screen are not wide enough with the bracket so I took that off for now. Got everything hooked up.
Issues im facing is siriusXM is not loading but nav is working and the vehicle does show active satellite data going through the testsettings.
can’t control rear HVAC on the screen and I had it locked before the swap so those are stuck on high heat full fan.
Bluetooth shows up as F250 if that matters.
