Terrible weekend with catastrophic ST failure
“Amp wiring”? There’s your problem. When the dealer finally discovers the parasitic draw on the battery they will charge you for fixing it, as in no warranty for aftermarket installations.
Related. I was getting low battery voltage after installing my amps. I was using the Nav-Tv unit for remote turn on. Turns out the can bus is active a lot of the time your car is off so my amps we running some amount of time after turned off. Would almost drain the battery. Solution was to run a separate remote turn on from an output in the fuse box that goes on and off with starting. Problem solved.
I did the same thing. Switched 12v through a relay to turn on all 3 amps and DSP instead of using the Nav TV output.
Chaseg08
Chaseg08
Golden, CO, USA
Thread Starter #23
I have my amp turn on wired into an unused circuit under the dash that is only powered while the ST is running. As soon as I hit the stop button, the amp turns off. I'm not using a Nav-TV yet.
abranen
Tacoma, WA, USA
Took my family to Lake McConaughy in Nebraska this weekend which is 4 hours from my home in Golden and happened to be 104 degrees. Made it just to the entrance of the Lake and every damn light came on. Hill Decent Control, ABS, Service Changing system, Hill start control, service engine, power steering went out. In a very short period of time, the screen shut down "to save power", the A/C turned off, and eventually the car started having idle issues and I turned it off. Friendly passerby stopped and gave me a jump. The ST started but all the faults were still present and it did not stay running once disconnected. Had it towed to Wolf Auto Ford in Ogallala and was left stranded. The dealership was closed and the nearest rental car company was over 50 miles away. I think the alternator may have quit. I don't know what else could have caused so many electrical issues.
Luckily we had a couple of friends camping there too and they came and picked us up. My mother-in-law brought my truck to us on Sunday and we packed up and went home. Called the dealership this morning and they can't even look at it until Friday. Pretty frustrating.
Same exact thing happened to my explorer 4 days ago! Dealership replaced battery, sent me home, only for my car to die again 10 miles later. They towed it back for me, then called today to let me know they had to replace the alternator as well. They will run a few more tests then hopefully I get it back - running well - in time for the weekend. Yes, totally frustrating and unacceptable
Chaseg08
Chaseg08
Golden, CO, USA
Thread Starter #25
Sorry man. I know your frustration. Still don't have any answers on mine. It's been two weeks now.
abranen
Tacoma, WA, USA
Two weeks..wow. And I will be without my explorer for a few more days
Chaseg08
Chaseg08
Golden, CO, USA
Thread Starter #27
Day 16: Called the dealership for an update today. They are waiting on a technical specialist to get back to them about an issue with the backup camera and one of the reverse sensors. They can't figure out what is wrong. This is all strange because none of that was an issue before. He couldn't be more specific because he was out the end of last week and the tech is out today. He was going off of the tech's notes. Small town dealership problems I guess. I asked what was done to correct all the faults/waring lights and he said it was the battery connection, which also doesn't make a whole lot of sense because I checked all of that and they double checked it all last Tuesday and said all the faults/warnings came back. That's all I could get out of him. The communication from Ford Consumer Affairs and dealership has been abysmal. I'm supposed to get a call tomorrow from Consumer Affairs. I wouldn't bet on it. I'll continue to exercise patience.
DaveG ST
Hurlock, MD, USA
Seems like many of us have been there with the ST. Mine was a bad throttle body that left my wife stranded. Ford Customer Service did take care of us for the most part. They called the dealer and made sure they provided us with a loaner. Same dealer also replaced the driver's side catalytic converter that should be replaced on all 2020's. I had been waiting for over a month for another dealer to get a converter. Anyways, you should have the email address of the Customer Service Rep and have them contact the dealer for you.
Chaseg08
Chaseg08
Golden, CO, USA
Thread Starter #29
Day 21: I asked for more specifics. The Tech is having a right front side sensor fault, invalid data from ABS fault, and lost communication with IPC issues. He said they can't recalibrate the camera system. They are talking with ford technical specialists about it. No estimate time to completion.
Chaseg08
Chaseg08
Golden, CO, USA
Thread Starter #30
Not having much luck with Ford Consumer Affairs either. I'm still without a rental or loaner. My case manager said I can use a rental car for a max of $45 a day. The cheapest I can find is through Thrifty...after taxes and fees a Chevy Spark is 71 bucks a day. What world are we living in?! Ha ha. I've asked if she can locate a loaner at a local dealership and I'm waiting for a response.
DaveG ST
Hurlock, MD, USA
#31
Not having much luck with Ford Consumer Affairs either. I'm still without a rental or loaner. My case manager said I can use a rental car for a max of $45 a day. The cheapest I can find is through Thrifty...after taxes and fees a Chevy Spark is 71 bucks a day. What world are we living in?! Ha ha. I've asked is she can locate a loaner at a local dealership and I'm waiting for a response.
They will give you a free extended warranty if you ask for it as a piece of mind due to issues with the vehicle. I did ask for the 150K mile ESP, but only could get the 75K mile ESP. I told the Customer Service Rep that they must not have much faith in their vehicle if they would only offer the 75K mile plan.
DaveG ST
Hurlock, MD, USA
#32
They will give you a free extended warranty if you ask for it as a peace of mind due to issues with the vehicle. I did ask for the 150K mile ESP, but only could get the 75K mile ESP. I told the Customer Service Rep that they must not have much faith in their vehicle if they would only offer the 75K mile plan.
Chaseg08
Chaseg08
Golden, CO, USA
Thread Starter #33
Day 31 and still nothing. My consumer affairs case manager called on Friday and said they have no update other than the tech is still working with the ford technical specialist. I can tell from the Ford app they started my ST and let it run for a while based off the fuel level but mileage hasn't changed. Hoping to hear some good news this week.
Ontario, Canada
#34
Okay, I will admit when I was wrong. The bad weekend has turned into a bad month. Sorry for your troubles.
Chaseg08
Chaseg08
Golden, CO, USA
Thread Starter #35
Thanks. I'm at the 48th stage of grief, or whatever. I'm just being patient and trying not to be a hassle to the service writer and one tech at the dealership. I limit my calls to twice a week just for updates and my fingers are crossed that they figure it out soon.
Chattanooga, TN, USA
Looks like it can be legitimately labeled as catastrophic now, that should really upset the nitpickers. If it happened to them, it would be catastrophic. Hopefully they'll get it figured out.
Chaseg08
Chaseg08
Golden, CO, USA
Thread Starter #37
I flew up to North Platte Nebraska Thursday morning and picked her up. Service writer called me on Wednesday and said it was ready. When I asked what they did to fix it finally, he said they had to replace a front right parking sensor and a battery cable was loose. They said that was the problem at first and then said it wasn't. I told them I wasn't satisfied with that answer but I'd gladly come pick it up and drive it home. I fully expect the issue to resurface. So I drove about 8 hundred miles over the last 5 days and everything is fine so far. Trying to get reimbursed for my flight but communication has been subpar, as expected and experienced over the last month.
Chaseg08
Chaseg08
Golden, CO, USA
Thread Starter #38
Well, same issue(s) is back. Dash lit up, no power steering. It didn't leave me stranded this time as I was able to make it home but of course all the Ford dealerships around don't have any loaners vehicles and their service schedules are booked weeks or months out.
DaveG ST
Hurlock, MD, USA
#40
They are required to find you a loaner while under warranty, per Ford Customer Service. Ford will reimburse the dealer if they have to get a rental. Easier said then done, of course. Worse case is to get a rental if you need one and Ford will reimburse you, at least partially.
