The Climate Control Icon Is Missing From The Bottom Of The Screen!
C_J22
Canada
Ford Explorer 2023 ST- Line
Hello, I'm new here and not familiar with car terminology, so please bear with me. Thank you for your understanding.
The climate control icon is missing from the bottom of the screen in my 2023 Ford Explorer ST-LINE!
I recently purchased a 2023 Ford Explorer ST-Line. I've noticed that the screen doesn't display climate control options, only the physical buttons do. I suspect I might need to use Forscan to enable this feature. Is there a way to do this without Forscan?
If not, could you please guide me through the process using Forscan? I want to avoid making any mistakes or complicating things unnecessarily.
Orwigsburg, PA
Do you have the 10 inch portrait screen?
The climate icon does not display unless it is enabled with forscan and then you need to install the Fmod resize mod to have it display properly.
here's a YouTube link explaining the process:
