Here's the settings I used from info I found. It got really close to my actual dyno numbers. I was mainly using it to see the HP/TQ difference from tune revisions.
If you check your door sticker, you should find your axle code. Mine is 3B. According to the ford towing guide for the Explorer, that corresponds to a 3.58 rear axle ratio, non-limited slip. Also, they list the ST only as having the 3.58 with the 3.0 ecoboost.
I'm sure that the 3.31 rear end was for the Platinum. The ST has the 3.58
That Ford Pro site also says it has a limited slip rear end which is wrong as the ST has has an open rear end.
