Correct... specifically due to the fact that I already dropped $1,500 on the Borla S-Type's (with Install) AND $1,400 on the SPD's (Installed 30 days later due to back order).
The 1st run Borla's in July 2020 had a few issues:
1. Bolt Contact Fitment issues with the mufflers scraping against the subframe bolts.
2. Resonator Defect where ALL of the fiberglass packing deteriorated over 3 months causing drone and it to sound waaayyy louder than it should have. (*** Due to these issue Borla gave me a Completely "Re-engineered" Warranty replacement - supposedly fixing their known defects.)
3. With the addition of the High Flow Catted SPD DP's...the already known Ford Factory Flex Joint rattle with a TSB in Nov 2020, became markedly worse, making it sound like a tin can POS Honda Hooptie!
I tried several cheap solves to mitigate the rattle/contact issues with no luck getting the sound profile/quality of exhaust system to be acceptable to me. (For the price point I paid and well known vendors I bought from)
I researched just swapping out/welding in Vibrant Resonators and upgrading the Flex Joint to a more rigid Performance Product...but for the costs of materials/Install....it made more sense to go with the complete Thermal Mids.
In retrospect - a full Custom 3" exhaust would have been right the option.
BUT the path I took led me down the Frankenstein approach of mating SPD(3") to Thermal Mids (2.5") to the Borla (2.25").
Now I just need to get it all Installed and will Report back with the results.
Sent from my SM-N986U using Tapatalk
