Finally received the skid plate! Ford cancelled my order using points. I saw it on JEGs for $180 so I ordered it back in Nov 2024. As expected, it was on back order. Anyway, I installed it tonight and all the appropriate hardware was included. Word of advice when installing, tighten the rear most bolts first as they are threaded into the aluminum tranny mount carrier. The fit is not perfect and there is a risk of stripping the threads in these mounting locations. One started to strip as I tightened the midpoint bolts first. I was able to save it, but you will get to 18 Ft/Lbs. prior to the skid plate mating with the tranny. mount. Of course, Ford added the blue loctite so getting the other 6 bolts in gave me pause but worked fine. Just to get them in was way over 18 Ft/Lbs. Now oil changes with the UPR drain will be a super-fast! Having that opening also allows you to inspect any leakage from the O rings on the axle to the driver side front. After install I did find that some pesky rattle on initial startup went away. Yay!
