Almost certainly it’s a toe-out problem. You must run a lot of negative camber to actually wear the tire excessively. About -1deg front camber is perfect for a street car. Zero to 1/8” total toe-in is good too. Alignment shops just get it in the “green” which has a huge tolerance. Specify exactly what you want so they have the correct target.
