Towing w/ the ST
Fresno, CA
2022 Ford Explorer ST - STAR WHITE
Does the window sticker also show the 52T option? That's the option for the class IV tow package.
It's only listed at the top under "Functional Standard Equipment". It is not an option.
Waterford Township, MI, USA
I have a 2020 ST and pull a 27’ travel trailer (23’ box) with a dual axle weighing 4,200 lbs dry with a weight distribution hitch and electronic trailer brake controller. We’ve taken it on 5 camping trips this year, 2 of which were 1000 mi round trips in tow. These 2 trips took us through the mountains (Smoky’s and Pisgah Nat Parks).
It pulls very well for its size but like someone said earlier that it’s not the pulling but the stopping which is most important. I had one white knuckle experience going down a mountain highway when a driver in front of me decided to stop when I was building speed on wet pavement. I didn’t hit anything but I did lose traction. More than anything it was a learning experience. The tow mode works really well, especially on hills. Once you plug in the 7pin it pops up on the screen that a trailer is connected and asks for the length so that the blind spot warning is extended (based on the total length of the trailer and truck) as well as disabling cross traffic when backing up. Depending on terrain I average between 9-11 mpg’s assuming approx 4,800-5.000 lbs w supplies and empty (white, gray and black) holding tanks.
Hi, What did you do for a gain controller? Empty my trailer is 1300#. Loaded its 4400#. Empty it skids the trailer, loaded it pushes me thru the traffic lights. What to do?
Ontario, Canada
I purchased a Curt controller that varies the force on the trailer brakes based on how fast you are trying to slow down. Faster you stop, the more pressure applied to the trailer brakes. When I get home I will find the model number. I also tow a utility trailer that ranges in weight from 1400 to 5000 pounds and the Curt controller keeps the trailer safely behind the ST.
Sacramento, CA
2022 ST
22 here and it came with a Class IV tow package FWIW
I know how a controller works. Got them on every truck I owned. So I take it that ford doesn't install one from the factory? Even thou I bought the trailering package? Federal law requires every trailer over 4000# to have a braking system. Ford claims it will tow 5600#'s? Do I smell a law suit here? Am I to trust my safety and the safety of others to some 3rd world aftermarket product?
Ontario, Canada
#27
My pickup can tow 9500 pounds and it did not come with a controller. It was an option, but I chose to install one instead.
Ddrummer
Frederick, MD, USA
#29
I also was surprised that electronic braking wasn’t included but a lawsuit? Nah, I like to make my ST work as advertised (400hp, AWD, 7 drive modes, 10spd trans, class IV hitch). Full of people & 2 big dogs w almost 5000# in tow it tows surprisingly well.
Sacramento, CA
2022 ST
#30
it comes with the ability to plug in a controller (which is a complete bitch to install). The "trailer package" is an option to have an built in OEM hitch, 4 and 7 pin adaptors wired up automatic sway protection, towing blind spot detection and tow mode options on the display and ECU. Controllers are generally installed OEM in trucks from all that ive seen - never in an SUV.
usna2k
Chesapeake, VA, USA
#31
Adding to this thread and confirming that we have a great vehicle for towing. This is our new to us 19' Airstream, we drove it home from Texas to Virginia over about 1,300 miles and over the NC mountains, it towed beautifully and I hardly felt it back there.
Ddrummer
Frederick, MD, USA
#32
View attachment 16150 View attachment 16151
Great set up! It’s amazing what this 3 ltr turbo can do.
drakin07
Benicia, CA
2022 Explorer ST Rapid Red
#33
Ddrummer and @usna2k - What tow hitches are yall using? I'm debating if I should get a distribution hitch for a travel trailer along with a brake controller. New to towing so any help and guidance is appreciated.
Buffalo, NY, USA
#34
We use a Husky Centerline TS Weight Distribution / Sway Control Hitch to tow a 3500lb 19' Travel Trailer. We have about 2500 miles on the combination thus far and it tows great. Our trailer tongue weight is around 400 lbs. Without the weight distribution bars installed the S/T backend sags pretty good...the max weight I think is 500 lbs.
We use a Curt Echo Brake Controller.
https://www.huskytow.com/husky-towing-32216-weight-distribution-hitch
https://www.curtmfg.com/dm/echo-mobile-brake-controller
drakin07
Benicia, CA
#35
Thank you for the help!. I went with the Curt Echo (hopefully no issues) and the equal-i-zer 4 point system (600 tongue and 6,000 tow).
voodothatido4u
MO
Just some general questions on towing with our St. Have a 7x14 ft V front trailer. (weights 2120 lbs/ 7ft tall.) Has Electric brakes dual axles. Going to be hauling a 1300 Lb. Trike with about 300 Lbs of gear in Trailer also.
First after reading the book and watching a video still not sure on settings in mode etc. My 7 pin Electric brakes should be more than adequate for stopping. Do you use only tow mode all the time or just for hills and mountains etc.? Going thru many mountains and about 3000 miles one way. Trailer pulls just great unloaded and in normal mode but would like some input from those who have already been there and done something similar. Thinking about using a wireless camera on the back of the trailer also? Thxs!
Your empty trailer alone is more than 1/3 of the towing capacity of your Explorer. Put it in tow mode the entire time you are towing your trailer and anything on it and leave it in tow mode. In-case you don't already know, you will need to put it back in tow mode anytime you put it back in park.
Ontario, Canada
#38
I am pretty confident that it only switches drive modes automatically when you restart the ST. Just placing the transmission in park does not switch the drive mode.
You may be right. I haven't had my 22' since I traded it in last year and my 25' isn't here yet. I remember with my 22' that either putting it in park, or, only whenever I shut if off, I had to put it back into tow mode if I was towing each time.
voodothatido4u
MO
That's good info I was looking for on towing. I towed the trailer home with my little 2016 escape and it did fine for the 20 miles.
Had been told the ST in normal would do it on level highways and roads but thought also the weight could be a problem without using tow mode. Thxs to all..
