TPMS Fault
Is there a procedure out there for pairing/re-learning a set of TPMS sensors? YouTube leads to a couple for other Fords, but neither work on this vehicle. I have now tried 2!!! different sensors and I'm still getting a TPMS fault. Unmounting/re-mounting tires is getting to be a PITA. I followed any instructions I could find such as drive over 20mph for at least two minutes, and even went for like an hour drive on each set to no avail. The first set was a cheapy set on Amazon and them not working I chalked up to being cheap and crap, but the latest set is supposed to be good. This vehicle is 315MHz correct?
These are the ones that are currently installed:
AmazonSmile: MORESENSOR Signature Series 315MHz TPMS Tire Pressure Sensor 4-Pack | Preprogrammed for Select 40+ American Brand Models | Replacement for 15136883 | Clamp-in | NX-S022-4: Automotive
I just pulled up the above link on Amazon. I have my vehicles in their garage. Amazon says those sensors do not fit my 21 Explorer ST. Sorry. May I ask why you wouldn't get a set of OE sensors? I suppose there could be differences between the 20' and 21' model years but these are the sensors that Amazon claims will fit a 21 ST (mine):
https://smile.amazon.com/MOBILETRON...1-1-6201-152-2&vehicleName=2021+Ford+Explorer
https://smile.amazon.com/MORESENSOR...1-1-6201-152-2&vehicleName=2021+Ford+Explorer
They look very similar with the exception of the metal vs. rubber stem.
