Transmisión stuck in Park
Nicaragua
Greetings, has anyone had the warning "Charging System, Service Soon", the vehicle starts and everything works, only the speed is stuck in park, any ideas? I use a translator, Explorer ST 18,000 miles.
So it won't shift out of park? Battery could be losing charge or alternator could be bad.
The charging system soon may be unrelated. Not sure if you have a code reader but here's something to check from Ford Boss Me:
G
Nicaragua
Thank you for your answers, the battery is in good condition and the alternator charging 14 volts, only one active code in Ford scan and in a scanner and they are related to the audio unit control module (ACM), these are the U 0100 which refers to loss of communication with the ECM / PCM. Already checked several modules, fuses, ground connections, only need to check the gear shift module that is under the center console. Thanks for the video, I will check the brake pedal connector
Not sure what year you have but my MY2020 had a gear shift module firmware update.
G
Nicaragua
It's 2020 but in my country the dealers don't bring the Explorer ST, only the lower models and they don't give me maintenance in their workshops
