Tune Only 1/4 Mile and 0-60 Record
SpeedOften
Londonderry, NH, USA
#41
It isn't the HP I am really concerned with, it is the torque and the transmission/clutches. I am curious how long they will last with 500AWHP for example.
One of the tuning companies said their test ST had ~300+ launches including street and track and 21k miles before needing a rebuild on the transmission with greater than 500awhp.
Revere, MA, USA
#42
Thanks to Adam@ZFGRacing my physically stock Explorer ST is now in the 11’s. Only thing that is different is E50 and a tune.
3.79 0-60
11.97 1/4
Here are the Dragy results!
Did you have to change fuel pump Inter cooler or anything else
LokiWolf
LokiWolf
Henrico, VA
Thread Starter #43
Nope, all stock parts!
Detroit, MI, USA
#44
That 10ree shouldn’t need a rebuild even after that..
Detroit, MI, USA
#46
Yes, that is a shift. We have worked on the 1-2, and 2-3...and minimized that peak, and decreased the time. It is even better.
you are using all stock with an E85 mix? don't you need a new fuel pump? you are crazy !
LokiWolf
LokiWolf
Henrico, VA
Thread Starter #47
Only thing a fuel Pump is needed for is if you are running E85 and want full potential...here is what I posted in another thread:
E50 is the highest concentration you can run with a Tune where you are getting full power on the Stock Pump. On my ST, everything else stock that was good for a 0-60 of 3.75. You get E50 by using an app to calculate how much E85 and 93(E10) to mix.
93(E10) - A tune from the same Company(ZFG) for 93(E10 - Percentage VA requires pump gas to have of Ethanol) was good for a 0-60 of 4.06.
E85, If you want to run it at full potential you need an upgraded HPFP(High Pressure Fuel Pump). It is a $1600 device.
ZFG offers an E85 tune that will work with the Stock Pump. It is turned back. Advantages is it is slightly quicker than a 93(E10) tune at a 0-60 of 4.01 for me. It also gains a 10th or a little more in the 1/4 vs 93. Other advantage is no mixing, just drive up and Pump.
Hope that helps a bit...
Sent from my iPhone using Tapatalk Pro[/QUOTE]
LokiWolf
LokiWolf
Henrico, VA
Thread Starter #48
Wow. That is crazy. How are you launching to get those numbers?
Here is an example of my standard launch. This was on 93, and was a 4.10...
Lows in the 50’s this weekend...I’m gonna try for a 4.0X finally.
LokiWolf
LokiWolf
Henrico, VA
Thread Starter #50
DO IT!!!
Tonopah, AZ, USA
#52
Nice right at 3K RPM.
Hi Guys
I have owned 6 ecoboost vehicles
All were tuned
I have used LMS & 5 Star
Currently using 5 star for our 2018 Expedition & 2020 Explorer ST
No need to be concerned
Trans TCM is reprogrammed as well to work with the PCM engine reprogramming[thankyou]
