Unable to get the rotary dial to work afte using ForScan
Arden Hills, MN, USA
I don't know what I did but now the shift knob will not rotate from park. I changed to secure idle it was disabled and now I am stuck in the driveway
All ST’s already have secure idle enabled.
If you wrote down the as built number like they tell you to just go in and put it back how it was.
Garda934
Well mine was disabled so I enabled it. Now I am stuck. Is there a way to reset?
Garda934
Got it back. Thank you UNBROKEN.
Did you try it before you changed things? It’s automatically enabled on all of them.
Garda934
I was listed as "Disabled" and I was able to move the gear selector with key in the house now it it is secure and unable to move the selector unless the fob is in hand.
