Mr. Unbroken, did you replace the silver surround on the steering wheel with the gloss black from 2021+? I saw that you replaced the matte black with silver a long time ago.
is it hard to remove? I’d like to do the gloss
Thread Starter #1,222
I didn’t but I’ve had the wheel apart a few times to recover it. The trim is super easy to get off once the wheel is off so swapping it would also be easy.
Thread Starter #1,223
Winter rebuild things are showing up.
I had Acoustic Elegance build these subs for me. They’re IB15AU’s and I’ll be cutting the tire well out to vent them outside the car.
Also swapping amps to a pair of Mosconi Pro 5/30’s to have one amp per side of the car. Should make for a good time. IMG_5289.jpeg IMG_5261.jpeg
Also swapping amps to a pair of Mosconi Pro 5/30’s to have one amp per side of the car. Should make for a good time. View attachment 27052 View attachment 27057
Wow, nice little upgrade there
Killer upgrade! What’s the purpose of venting outside the car?
Thread Starter #1,226
They will be in an infinite baffle configuration like my midbass are. There is no enclosure.
Ok. I think we used to call them “free air” woofers or is that something completely different?
Thread Starter #1,228
Similar for sure but not the same. IB will get extremely low on very low power and I’m after that single digit response. lol
KU3050
Honolulu, HI, USA
I needed more adjustment range than the fixed length FenFab toe links give…so these are from Steeda are going on tonight.
Unbroken, I'm about to order Steeda toe links is it worth it to get adjustable vs non? I will be lowered
Thread Starter #1,230
Previously I would have said just get non adjustable but honestly if you’re spending the money you might as well get the adjustable ones. They do make setting toe really easy.
Rhode Island
2020 Ford Explorer St
