Thread Starter #1,303
I didn’t like the tiny oem hardware holding the skid plate on…and I do like overkill…so I added 5 riv-nuts for M8-1.25 socket head bolts and it’s definitely solid now.
Thread Starter #1,306
I was figuring you’d do that. Also it’s super unchill if you don’t give us the how to or a way to buy your lower part
I started a thread to show everything that’s being done in case anyone wants to mimic the process. As far as buying…I highly doubt anyone would be nutty enough to spend what this costs. lol
Labor alone is more than what both screens cost.
Pleasant Valley, MO, USA
Thread Starter #1,309
Ok…do the China dual 4.5’s fit? Yes and no. Yes they fit the bumper just fine and the length is long enough to slip onto the muffler outlet but the tip inlet is substantially larger than the muffler outlet. I had to cut a sleeve from 3” tubing then cut that in half to take up the slack. Once I drive it a bit and let the exhaust settle and readjust it I’ll have throw a tack weld on to be safe.
