Hull, GA, USA
Forgot to post the new wheel cover completed. I had to shrink a few spots around the top spokes but it came out virtually perfect. View attachment 19772
Any tips on getting the seems at the 3 and 9 o’clock position to come together tighter?
Thread Starter #1,164
I don’t recall having any issues there. A few places where I needed it tight I just pulled the string harder. Mine was a hair loose where your thumbs rest in the little indents…I soaked the leather there and hit it with a heat gun the shrink it and it fits perfectly.
Ormsby11
Milwaukee
Unbroken, check your messages please! I sent you one about the driver seat. I saw before you took out some foam since you were tall. I have the same issue
Thread Starter #1,166
Haven’t had much to do lately…but I finally needed a new battery so I swapped the H6/Group 48 XS Power for an H7/94R X2 Power today. The 94R is about 1.5” longer but drops right into the hole so all is well. My audio ground wouldn’t reach because of that though so I had to improvise with a short piece of wire and a small distribution block to bridge the gap. I forgot to take pics with the cowl opened up but you a kinda see it squeezed in there.
Polizi212
10LBS of stuff in a 5LB bag!!
