Sign Up! To view all forums and unlock additional cool features
Great video! Did you also get the upgraded check valves? I just got my kit and I did order those along with the billet PCV but I can’t tell if the check valves are upgraded or not. They look just like yours in your video.
Has anyone gotten any results from draining? I have the UPR installed with all extra goodies you can add. I checked the drain plug at or around 600 miles and NOTHING. It’s bone dry. Is that normal??
Double check your hose connections that they’re all on the right connectors. I bet if you unscrewed the can and looked inside, you’d see some oil. It may just not be enough to come out of the drain valve. New catch cans are completely dry so the media inside needs to get saturated before it starts to drip into the can.
