What Brake upgrades are available for stock wheel size?
A 20” wheel barrel will fit the Rotoras. The spokes may not though…you may need a spacer.
Canada
so far looks clear except for the wheel weights but can move them in slightly to clean the brakes. I think a spacer is the solution.
suggestion on best spacers to use? eibach or what?
Canada
Correction. tech just showed me- the rears don’t clear. the caliper sticks out more then the fronts. would have to be a pretty big spacer to clear them or a different rim with a bigger offset.
Offset isn’t what matters, it’s spoke clearance.
