Traded the modded Rapid Red 2020 in on the new 2023 Atlas Blue. Will tweak a few things like add colored bumper plugs, Optimus hitch cover and nicer tail pipe ends. Maybe down the road may add some stuff but it is kind of nice just leaving it stock for now. IMG_3897.JPG
Did a few things. Replaced my front brake pads; had Powerstop Z23 and put in Z26.
Installed the rear LED kit from Houston Speed Freaks. I previously had some other LEDs for the license plate and reverse light, but stock incandescent then signal. These HSF bulbs blow those out of the water! Great bulbs at a great Black Friday price.
Also installed some floppy paddle extensions because I felt like wasting $40.
Suprawill1
Maryland
Happily installed the Rove R3 dash cam. Front, back and interior.
Going to be flashing the newly arrived ZFG tune soon.
Fixed something that always bothered me with the Fenfab ECU cover. I had put plastic loom around the wiring harness, but the huge plug was always touching off against the cover. Finally pulled the clip from the core support, cut the larger Christmas tree clip off, and drilled a hole about 3/4" over so the plug butts against the washer reservoir neck, and tucked the wiring under the core support. Now looks much cleaner and the plug isn't touching the ECU.
Also adjusted my hood bumpers to level the hood with the fenders. Only took me 3 years to finally do that!
Suprawill1
Maryland
Looks good! Do all the black covers come with the "Twin Turbo" patch? The pic on 5 Star only shows the red cover with just the "ST" on it.
Thanks! Nope, I added that. Wanted to spice it up a little bit so bought that badge since it's clean and simple. It's from a Nissan RB26DETT, the R32-R34 GT-R motor.
Suprawill1
Maryland
Ahhh, also a great car! Thanks!
Canada
Diode Dynamics Stage Series DOT/SAE x 2
Diode Dynamics Stage Series x 2
Suprawill1
Maryland
Cut my hood up to do a factory look install of my Jeep Rubicon hood vents. I’ll start the finish work tomorrow….have to let the panel bond dry overnight View attachment 20948 View attachment 20949
This is not a Ford Explorer anymore! It's an Unbroken Explorer! :)
You should change your name to "Totally Revamped".
I'm sure with what you call OCD, those vent holes are factory symmetrical!
way2far
Tampa, FL.
Traded the modded Rapid Red 2020 in on the new 2023 Atlas Blue. Will tweak a few things like add colored bumper plugs, Optimus hitch cover and nicer tail pipe ends. Maybe down the road may add some stuff but it is kind of nice just leaving it stock for now. View attachment 20867
Looks great. Congrats!
From a curiosity standpoint, was there something in the newer model that made you want to trade in your red one? None of my business if it had to do with finances or whatnot. I just got my 2020 ST a couple weeks ago so I was just wondering if something in the new model attracted you.
First round of bodywork on the hood vent project. I’m super stoked with how it’s turning out. IMG_2315.jpeg
Prospect, KY
I took off my stock 21" wheels with original tires and put on my dedicated snow tires. Those stock wheels are heavy. The snows are on 18" Enkei wheels from tire rack.
Boyd
Tennessee
GF installed the new hatch badge on her ST. Looks fantastic on the Star White, even when it's Daily Driver Dirty.
She also installed the Auto Stop Eliminator.
Next week she's removing the front end to do the grill badge. And hopefully her Velgen's show up soon... been on order since 11/24. ST rear badge.jpg
Ryan1024
Mount Pleasant, PA
Added carbon fiber decals to the ST logos
Added black plastic center console cover
Windows getting tinted tomorrow!
Looks good! So, the hood vents are for under hood ventilation and not directly connected to the intake?
Correct. Although I have a thought brewing in the back of my head I may play with this spring to directly feed the airbox.
Suprawill1
Maryland
Like I 'knew' you would! lol
Deerfield beach
Explorer ST
First attempt at doing non pre cut vinyl tint, had the anchor room side marker on there but wanted to cover up the chrome on the top.
Might remove the anchor room side marker tint and replace with the same tint I have running along the top
