Sacramento, CA, USA
Today I installed the Steeda Rear Toe Links, haven't driven it yet but I have the alignment scheduled for tomorrow. Install was pretty straight forward and they are really nice quality peices.
Punta Gorda, FL, USA
If you set the length exactly what the factory pieces were you really shouldn’t need an alignment. I didn’t!
That is to say that a car as set from the factory wouldn't/couldn't be out of alignment. That simply isn't the case. It's a great idea to at the least, have the alignment checked. No offense intended.
bguild
Massachusetts
Two days ago swapped out my Bench 2nd row for Captains 2nd row.
Maryland
De-installed the WeatherTech rain deflectors. Fine around town but too much wind noise at higher speeds. Burned $130.
Sacramento, CA, USA
Yeah I had it real close, the driver side was within specs but the passenger side was slightly out just enough to turn it red. The tech did a good job getting them both on the money, tires are too expensive to risk it anyway so it's worth it to me.
BigAnt75
Haslet, TX, USA
Lol it’s already loud enough with the damn roof rails and whistling!!
Maryland
I must have gotten lucky - mine is reasonably quiet.
Whistling is usually the side mirror housing.
Omaha, NE, USA
The wind noise is the roof rail pieces that come down to the windshield on the early models. Anything Over 40mph sounds like I have a window cracked open.
Sacramento, CA, USA
Just got word ... front Swaybar is coming! 2-3 Weeks!
TJ
Great news! Since the rear was designed to balance with the OE front bar, will there be changes for the rear?
Central Cal
Used Forscan to turn off Double honk and allow Bambi mode. Installed the Autostop eliminator since all the Forscan attempts failed. Works like it should now.
Now if I could find the decal many of you have put on the front strut tower cross brace. They look good!
Edit: Oh, and the ST center caps!
Charlotte, NC, USA
Good start. Check out ESTY or Amazon for those type of things, also check out the brushed aluminum peddle covers. Low cost and functional upgrade.
St. Louis
Took a pic of my new to me 21. Build date 11/20.
