Wheels off gets you better access to the 2x 10mm fender bolts on each side. A panel popper tool helps. Torx bit for the air sensor. Watch the Fat Guy Builds video a few times before you do the install, then keep it handy and pause the vid as you do the install.
Its an easy install, just take your time.
