So i just noticed my driver side window seal near the side mirror has a pretty good slice, It made a hole in the seal and water can probably go into the tube of the seal,
is there any possibility of causing damage to the door from water getting in the door and possibly freezing? Or damaging electronics in the door?
im 99% sure it was the tint guys I used because I would have definitely noticed,
but now my ocd is kicking in and Im not sure if I should just silicone it or replace the whole seal
Has anyone here had exp with changing the top window seal of the door? Or if theres no change of damage should I just use some black rubber silicone?
