Winter Rims
AaronR
T0E 2A0
I’m on the hunt for a winter tire and rim package Do the rims have to have the 70.5 bore size ? What do the lowest number that will still work ? Thanks
What do you mean by lowest number that will work? Yes, the hub bore is 70.5mm on these cars.
Rims need to be at least 70.5 bore size. Larger than that you can use hubcentric rings. You CANNOT use rims that have a smaller hub bore size, like the 5th gen explorer rims.
