At some point my front heated/cooled Seats decided to stop working. We took a long trip and I periodically check how things are running with Forscan, and I noticed when I read the DTC's the SCME failed to read. This was new. I also got an error about the rear seat climate control, I don't recall the exact wording. We had a bunch of stuff up against the rear controls and I believe a bag was pushing multiple buttons at once, because it cleared itself once I moved everything. The SCME error did not. This coincided with the driver and passenger heated and cooled seats failing to work. No blower activation for the cooling, no heat on heating. Both seats though, which points me towards a module failure. The heated steering wheel does still work, all fuses are intact, all underseat connectors intact and plugged in, and the controls still turn on and function as they always did. All the "multi-contour" seat features still work as well, like massage.
My question is, where is the SCME and is this the likely culprit? Is it integral with the seat modules? Or is it the control module in the dash? I really can't find any information on this, though a post on the F150 site described it as integrated with the DSM now, which I understand is under the seat. I checked and pulled all relevant fuses. That did nothing. I tried to do a module reset with Forscan, but as I suspected, there's no communication with the SCME module. There is communication with every other module.
I'm stumped, and don't want to replace the wrong part. The dash controls were my original suspect, but now I'm not so sure. Thanks in advance.
