Bora Wheel Spacers 1.5"
Buffalo, NY, USA
#41
Can anyone share their alignment specs with similar mods, specifically the rear?
  • H&R springs
  • 1" Bora spacers front
  • 1.25" Bora spacers rear
The reason I ask, is my shop aligned it to "factory spec", but visually the ~2 degrees camber in the rear does not look factory. I dropped it off to them with the spacers already installed; wondering if they used that suspension geometry as a target to align.
I'd like to push back and try and get a bit less camber in the rear, unless others on here have similar camber specs with spacers/springs and it's simply not possible without further modification.
Kosai
Huntington Beach
Anyone have wheel bearing issues since running wheel spacers? I was told how much more stress and pressure there was on the bearings and now I’m afraid
Hope, BC, Canada
2022 ST
#43
I'm no engineer but I would assume that the larger the spacer, the greater the stress on the bearings; with so many people using spacers on the road and even on ST's you'd think you would've heard something by now. Nowhere in the group have I found a negative review and I think you should just do what you want. Spend money to drive a nice car, to mod that nice car to what you want, and to fix anything that a mod breaks... live YOUR life full, fast, and hard!!!
There isn't any question that the further the load/leverage is from the center of the bearing, the greater the stress. That being said, it's nearly impossible to put a real statistic on how harmful it is, since there's no way of knowing what the engineers designed as leeway into the bearing specs.
Will a 1.5" spacer put more strain on the bearings and increase wear? Absolutely. Would I put this on my vehicle to achieve "perfect" fender alignment? No. However, if you're not applying significant lateral loads, it probably isn't going to cause a catastrophic failure unless you ignore the signs.
SmittysST
SOCAL
2023 FORD Explorer ST
#45
Good stuff! Seems like the perfect space would be 1.25" front and 1.5" rear....
No…if you just have to use spacers with stock 21’s then perfect is 1” front and rear with rear camber set to -.5°.
SmittysST
SOCAL
#47
Okay, so no spacer in the rear is recommended?
SmittysST
SOCAL
#49
It says front and rear.
Copy that, see that now. I do remember reading a thread where you commented that the rear is inset more than the front, and yes it does appear they do, so with rear camber set to -5* evens that out? Thx again!
ARC
Oak Lawn, IL, USA
2022 ST Black
#50
But anything less than 1.25 spacer and you will have to cut the studs. Which is a pain. that's why I just went with 1.25 spacers.
