More goodies: FenFabrication Cold air intake and IC Piping
Nine29
Motown, MI
Wow! Unreal, clean work.
Think I'm in your neck of the woods at Atwater. Next time I'm here I'll message you for a beer.
definitely I’m down! I’m in GP Woods
I'm in the Farms...would love to see (and hear) your work!
Nbk4t5e
San Antonio, TX, USA
Got it back - oh man does it sound amazing! So much more turbo, so much more growl from engine, and the bov sound is great. It’s a longer higher pitched sound - best I can explain is it sounds more like a Supra but not over top import. The BOV that all the Supra’s have is the HKS SQV. I have the turbo smart race port. There’s snow on ground AGAIN so I just spun the tires trying to do 0-60 runs so will have to wait for dry roads to test.
Going to dyno in next few weeks. I did some logs on way home running my old tune so obviously I have to get a new one to take advantage of all the new airflow. I’m pushing 37psi at peak and turbo airflow 56.04 lb/min. Based on the below which I’ve found on a few sites that should be 532-588hp estimated at flywheel - I’m guessing low 500s to wheels but will know for sure in a bit.
As a very general rule, turbocharged gasoline engines will generate 9.5-10.5 horsepower (as measured at the flywheel) for each lb/min of airflow. So, an engine with a target peak horsepower of 400 Hp will require 36-44 lb/min of airflow to achieve that target.
Any sound clips ?
K
Grosse Pointe, MI, USA
Thread Starter #124
Any sound clips ?
So hard to capture while I’m driving - windows up is too quiet and windows down lots of wind noise but tried to get the intake / bov noise here...bov is so sick.
Intake BOV
Nbk4t5e
Intake BOV
I’m ready to purchase lol. Also I’ll buy the other BOV if need be. Will the HKS fit ?
K
Thread Starter #126
Yep HKS, Greddy, Turbosmart etc will all work. Plenty of room. The Turbosmart is what Brett typically uses so I went with it and it’s a great happy medium between what it was and Supra territory (don’t know any other comparison to use).
Nbk4t5e
Okay great. Looking forward to it.
Did you get any IATs before and after?
I was a little surprised at how bad the stock intercooler is, 36° outside with an intake temp of 64° with the stock intercooler.......
37psi is insanely high. That doesn’t sound right.
I think he's talking absolute pressure (PSIA) not gauge. However, I have a question, where are you getting the mass airflow (lbs/min) numbers?
Fairfax, VA, USA
it should be reducing pressure with the intake and exhaust work flowing better.
btw, that looks sick as hell.
K
Thread Starter #132
Correct, that 37 psi is “manifold absolute pressure”.
I get it from vcm scanner - I do some 0-60 pulls and 3rd gear/4th gear pulls and scroll to where I hit redline basically and see the numbers on the readout there. It’s capturing close to 100 categories.
That makes all the difference. Pull out that 14.7 and it’s a lot more realistic.
Atmospheric pressure.
Commerce Charter Township, MI, USA
Let’s meet up this week!
I might also be up for meeting, depending on the day and time. Kids have basketball games all week, except Weds. I have class and work Thursday... But, don't schedule it around my schedule. If you put something together, and I happen to be available, I'll try to be there. I just got a bunch of my interior CF parts too...
K
Thread Starter #137
let’s figure it out through messages. Thursday says 5-7 inches of snow so obviously before then is better
K
Thread Starter #139
Another clip of the glorious sounds - purposely not accelerating fast so you can hear least exhaust as possible - some nice intake and bov sound
Intake BOV 2
