Rear end damage
Somalia
I didnt see the tailgate dent before, sounds like you need to make sure frame is not bent, I hate people who drive w/no insurance, he should be exectued
IconicSTallion
Albuquerque, NM, USA
Thread Starter #22
So now the vehicle won’t start certain times and when it does start it won’t let me switch the gear from park to drive. Waited 1 hour for a tow service who was looking for the fuel rest switch and ended up breaking a inside door plastic floor panel and another 1.5 hours for a tow truck that couldn’t tow a 4wd vehicle. Finally by some miracle the vehicle started up and let me switch gears to drive home. Very stressful weekend.
BSweet804
Hanover, VA, USA
Can you share any updates on your repairs? I was hit last weekend and have similar damage. Are your sensors messed up? My repair shop can’t even look at it until 2/22. Same scenario…. “Sorry I wasn’t paying attention.” I plan on getting a tow hitch so next time someone can run into that instead. Seems fair.
ZRX61
L A, CA, USA
They sprayed that expanding foam stuff in all sorts of places, I first noticed it at the rear of the front fenders when I had a front door open. You can probably poke it back behind the panel it fell out of.
Minneapolis, MN, USA
Wouldn’t using that hitch have more potential for serious frame issues? I don’t know but if the force is all going into one point central to the vehicle frame I’d imagine worse frame damage. At least in this case the force spreads out and wouldn’t affect each component as bad. Obviously more to replace, but less catastrophic.
Somalia
someone on one of the Facebook groups posted about a read end explosion/failure recently
