ZFG93 baseline
Just curious, did you ever make it to the 11 second 93 tune pass? I'm working toward a consistent 12.00-12.03 second 93 tune pass now.
If we had been trying at a different time of the year…I have no doubt. It was July/August in south Texas so probably could t have picked a worse time. It went 12.0 and we threw in the towel because I was doing other mods and moving to E50.
Lake Wylie, SC, USA
Understood. Thank you for sharing. I have no doubt that Adam will get me dialed in, performance wise. The rest will be up to driver, surface conditions and weather.
Oregon
What are you guys doing to hit 12 flat with a 93 tune? Adding a splash of ethanol?
Radguy
Doctor
Brockville, ON, Canada
2021 Lincoln Aviator Grand Touring
60 oz bottle of Absolut vodka in the tank!! Makes it run and feel sooo much better!!
CareerFiremanGuy
I agree, it is a stupid question ...
Let me guess, Santa still delivering coal to your stocking? Lol
Lake Wylie, SC, USA
I did it brother (My time is on the left)! Thanks to continuous tune revisions, great weather and a perfect launch, we got this ST into the 11's on a 93 tune (Running an E26 blend). I ended up taking 2nd place at Street Car Takeover Rockingham this past weekend, in the 12.0 index class.
New Orleans
I was running an E26 blend this weekend and hit an 11.96 on my 93 tune.
I’m no where nears those numbers as per draggy. I guess I need to get on the track and make some passes. What tires are you running? Factory?
Lake Wylie, SC, USA
#30
I'm running the stock 21" wheels and Pirelli Scorpion Zero A/S tires. When I'm on the track, they're deflated down to roughly 25.5-26 PSI. I then re-inflate them before leaving the track to the factory 33 PSI.
I hope this helps.
Lake Wylie, SC, USA
#31
Do you test the ethanol to know exactly what percentage it is?
I recently installed a combination of Innovate Motorsports MTX-D ethanol gauge and sensor, and Fenfab ethanol sensor installation kit. It works beautifully and makes life so much easier when blending fuels.
CareerFiremanGuy
I think it would be helpful when owners post their ST's drag times that they note if they're 1 bolt rear or 2 bolt rear and if they are using any rear diff braces.
It would help put things into perspective.
New Orleans
#33
I hope this helps.
That’s awesome! I appreciate the information
Lake Wylie, SC, USA
#34
Sadly, I have a 1 bolt (Actually a 3 bolt) rear differential. I have been testing/using the AWR Racing differential brace for a couple of months now, with no issues. I'm at the strip at least every other weekend, beating on it. The two piece brace is extremely beefy and well made. I hope this helps provide some clarity!
Lake Wylie, SC, USA
#35
Glad to help. I have had no issues with the Pirelli's so far however, I do intend to switch to Continental Extreme Contacts (and a lighter, forged wheel) whenever it's time for tires. I've heard amazing reviews for those tires.
CareerFiremanGuy
Sadly, I have a 1 bolt rear differential. I have been testing/using the AWR Racing differential brace for a couple of months now, with no issues. I'm at the strip at least every other weekend, beating on it. The two piece brace is extremely beefy and well made. I hope this helps provide some clarity!
It helps a ton, thanks for the info CB17!
