Installed Livernois Tune
Bocian77
Brantford, ON, Canada
#41
So I installed it yesterday, so far so good, but I haven't been able to really step on it because it's been a bit snowy here. They instructed me to install a revised stock tune first and then the stage 4.....why I have no idea but I will say it seemed to cure my rough shifting issue which was my only gripe before, but I wasn't sure if it was the tune or the car.
Thanks. Much appreciated. I had the 91/93 tune prior to today. Flashed it with this stage 4. We'll see how it goes. All the best.
amaisonet
Bristol, CT, USA
#42
Still waiting to see if anybody can get at least a 0-60 on an ST with a LMS tune....
Pre stage 4 tune (going to add on today)
0-60 - 4.27
1/4 mile - 12.54
LokiWolf
Henrico, VA
#44
0-60 - 4.27
1/4 mile - 12.54
Decent numbers. Curious to see what the V4 tune gives you!
amaisonet
Bristol, CT, USA
#45
Just curious where does ZFG sit with a stock ST 93 tune? I believe a lot are saying it is faster.
Grosse Pointe, MI, USA
#47
I think Loki got down to 4 flat 0-60 on ZFG 93
I'm at 3.91 but also have whipple ic, downpipes and 3" exhaust. Just got new charge pipes and cai and waiting for snow to stop so i can actually test 0-60. Dyno next week.
LokiWolf
Henrico, VA
#48
What @blaster9 said. My best is 4.01 on 93 alone. Stock everything. 12.32 in the 1/4.
#49
0-60 - 4.27
1/4 mile - 12.54
Wow. Those are the best numbers I've seen for Livernois by far. Are you stock otherwise?
Jacksonville, FL, USA
#50
If i could get those #s with my current setup (incl. A/Ts, roof rack/basket/tools/etc), I'd be happy :)
amaisonet
Bristol, CT, USA
#51
Yes completely stock, those numbers are my best. The more consistent numbers are .1 / .15 seconds higher for both.
LokiWolf
Henrico, VA
#52
Any numbers with V4 yet?
amaisonet
Bristol, CT, USA
#53
A3939601-DEE7-422B-ADC8-2DDB13DD9D4F.png Could not launch as hard as I wanted because of spinning. It snowed here last night and salt was still on roads. Around 2000/2100 rpm instead of 2500ish. Could not do any real 1/4 mile due to traffic. Best I got was 11.51 with letting off at the very very top.
I think you meant 12.51. lol
Looks like Livernois is right there with 5 Star on power and Dragy times.
LokiWolf
Henrico, VA
#56
Agreed. Their V4 has definitely upped the game!
PhilST
New York
#57
Not too bad. Thier setup with tune $500?
amaisonet
Bristol, CT, USA
#58
Yes! I believe it is 400 now or maybe it was 600 and now 500 I can’t remember. I have had no problems with customer service either. Idk how fast other companies are but I received the updated stage 4 within 12 hours of when I requested it.
Airizona
#59
I'm a bit confused as it's mentioned that you are all stock yet saying stage 4 leads me to think of mods having been done. I have livernois also and interested as to what stage 4 is.
LokiWolf
Henrico, VA
#60
LMS released a new revision to their tunes for the ST, they are calling it Stage 4. They used to call them Versions. Stage 4 is confusing... it should be V4.
Here is the YT Video discussing it.
Sent from my iPad using Tapatalk Pro
